Author Topic: To tile a dome. ¿Possible?  (Read 33524 times)
Alumno51
« on: March 21, 2017, 02:20:51 pm »
Hello everybody,
Last week I took a 3D course and the teacher, in his spare time, taught me RailClone Pro. He explained to me the basics and I want to acquire the pro license since, however I want to solve a doubt before (as my teacher couldn’t answer me). Can you help me?
Would RailClone help me making a curved dome ceiling? I’ve tryed to create it from the oficial document called “slate_tiles”, creating a circular spline and a fourth segment. Then, the dome-shaped ceiling is formed but the tiles collapse and it’s imposible to me to avoid it. I guess I am doing something wrong. My question is, can I make circular roofs with RailClone? I can’t find the way… If I us one model as terrain i loose the control.
On the other hand, I have to say that it seems to me a very powerful software, however it’s difficult to me to exploit it to the maximum.
Regads and thank you,
PD: Sorry for my bad english
Re: To tile a dome. ¿Possible?
« Reply #1 on: March 21, 2017, 04:23:35 pm »
I would suggest you to check following "tiles on round roof shapes with railclone lite or pro?" post, where you can also find attached sample scene. As mentioned there: "... the circle is in the X Spline input and the roof profile is in the Y Spline Input. The profile itself should be drawn on the spline object's local X/Y Axis - Z is ignored. "
Also you might find the "Interesting structure , help needed :)" thread helpful. There you can find another example.
Let me add, that the Curve Steps value needs to be increased to get better results. Hope that helps.
Alumno51
« Reply #2 on: March 21, 2017, 05:09:26 pm »
Wow Michal, it's amazing to count with your help. I am very grateful. Now I want to try it!
The only point is that I can't found the attached file.
Thank you for your time,
Alumno51
« Last Edit: March 21, 2017, 05:47:55 pm by Alumno51 »
