Author Topic: is this supposed to happen?  (Read 30529 times)
Alexander Alvarez
« on: August 19, 2022, 04:44:10 pm »
clipping area + top --> not placing the objects on top of each row
clipping area at different angles creates weird placement of geometry
how can these be fixed? video attached
Re: is this supposed to happen?
« Reply #1 on: August 22, 2022, 09:20:40 am »
Thanks for contacting us. That's normal behaviour in this case. The A2S generator always creates a rectangular array and the segments in the top input are assigned to the top row of that array. Clipping areas are always calculated once the array has been created, removing or slicing segments to remove them from the rectangular array. I'm afraid each column isn't calculated independently with a top segment at different height.
I hope that makes sense,
