Author Topic: Install Problem  (Read 108380 times)
Kaelig
Install Problem
« on: July 31, 2024, 08:45:53 am »
Hello everyone, i just got Railclone lite and finish the Installation but i have no idea to to use it in 3ds max, i have no Railclone icone on my Ui. Do i need more step after the Installation is done ? Thank you !
Re: Install Problem
« Reply #1 on: July 31, 2024, 09:14:34 am »
Which 3ds max version are you using? There is no need for any additional steps - once installed, you should find it within the 3ds Max Command Panel under Geometry > iToo Software > RailClone Lite. Let me add that you might find our "Getting Started with RailClone" guide interesting and helpful.
Kaelig
Re: Install Problem
« Reply #2 on: July 31, 2024, 10:04:56 am »
Hello, thank you for your anwser, i'm using 3ds max 2025, but no Railclone or Itoosoft doesn't appear anywhere on my command panel, i have 3ds max and Itoosoft on différent hard drive, maybe it cause problem ?
Re: Install Problem
« Reply #3 on: July 31, 2024, 10:09:48 am »
3ds Max 2025 is currently supported in the beta version of RailClone, which can be downloaded from the User Panel under the Downloads - Beta versions section. If you do not have a Pro license, you'll need to wait until the final versions are released, along with the Lite versions. Thank you for your understanding.
