Author Topic: RC Lite - deformation  (Read 168596 times)
martin.bdzoch
« on: February 20, 2025, 02:39:39 pm »
Hi people. Can you help me please? I am trying to create stairs with my own railing but - When I create a line for my railing to follow, my railing starts to deform and I can't create the railing as it should be in real life. Could you please help me how to set it up correctly? You can see it in an attachment on a picture. For example sphere isn't sphere. Thank you for your help.
Re: RC Lite - deformation
« Reply #1 on: February 20, 2025, 03:04:07 pm »
Hi Martin,
Adjusting the Flat Top and Flat Bottom values should help. As mentioned in our documentation, when working in Vertical mode, these parameters allow you to flatten the top or bottom of a geometry. The values define the maximum distance (along the Z-axis) where the effect is applied, starting from either the top or bottom of the geometry. This feature is especially useful for railing posts and works as a combination of Vertical and Stepped modes within the same segment.
martin.bdzoch
« Reply #2 on: February 20, 2025, 04:27:03 pm »
Hello.. its going on thank you but I have next problem - look its not looking good. How I can give it on every step or every second step in the middle? Should be it on floor not in air.
