Author Topic: Slicing of ends  (Read 26335 times)
BohaStudio
Slicing of ends
« on: December 31, 2013, 08:44:02 pm »
I am using the floor tut to create an outside porch with two different chamfer boxes one at 18"x36", and the other 18" square. The problem I am having is it is slicing the ends off at the end of the array and I cant figure out how to get the edges right. Could someone help me figure it out.
Re: Slicing of ends
« Reply #1 on: January 01, 2014, 07:13:30 pm »
This behaviour is normal, because the boxes must be sliced to fit the array size.
Although it's possible to add custom segments to the end sides (Right and Top), this solution is not valid for clipping areas. Usually it's better to create a frame around RailClone, as shown in the tutorial.
