Author Topic: itoo lite csn make the geometry follllow the nside of a spline rather the outsid  (Read 18252 times)
512Pixel
I have create a spline and then used the following tools in itoo to create the geometry .please  see attachment  MY issue  i would like the path to made on the inside of the spline . the geometry is curtrently on the outside of the spline over laps the road
Setting the General - Alignment - Y: Bottom for used Segment (or using the Pivot option and adjusting the Pivot Point accordingly) should do the trick. Hope that helps.
Best regadrs,
