RailClone => RailClone Lite => Topic started by: adnanmalik23 on June 24, 2013, 04:44:23 am
can any body tell how can i connect the flyover with the road whach is going downward.i showed it with circles..any idean to how make that .i shoed my problem in pictures plz see and tell me howto do that ??
In this case is necessary to edit the RailClone mesh manually. There is not any tool to automatize the joints creation.
manually ?? how
I mean using the Max tools, as if you were working with a standard mesh: slice, booleans, edit polys or whatever tool you use normally.
