Toggle navigation
Login
Register
RailClone
RailClone Lite
No Size or Spline on X
« previous
next »
Print
Pages: [
1
Author
Topic: No Size or Spline on X (Read 119108 times)
ss
Newbie
on:
May 02, 2024, 12:18:41 pm »
When I tried to use 'Rail Clone Pro 5.2.2,' it didn't work and the message has appeared.
In 'Style' rollout just below the 'Open Style Editor' row of buttons, I have "No Size or Spline on X" in RED.
Are there any solutions?
I use 3dsMax 2020.
Logged
ITOOSOFT
Hero Member
Re: No Size or Spline on X
Reply #1 on:
May 02, 2024, 12:27:05 pm »
Based on the warning message, there is no spline wired to the
Spline
X Spline
input. Alternatively, you can enter a value in the
X Size
parameter of the used Linear 1S / Array 2S Generator. I hope that helps.
Logged
ss
Newbie
Reply #2 on:
May 02, 2024, 12:47:54 pm »
Thank you for your help.
I have already wired path curb to Spline input. But, I can't enter the value of X Size, because the window has turned gray...(I attached a screenshot.)
Logged
ITOOSOFT
Hero Member
Reply #3 on:
May 02, 2024, 02:07:14 pm »
Once you link the
Spline
node, the
X Size
parameter isn't available (because it's taking it from the wired spline). Please double-check that you've selected the spline from the scene - its name should appear in the
Spline
Object
button in the
Style Editor
/ under
Base Objects
Spline
in the
UI
. If so, it might be that there's some problem with the path. I would suggest you assign another path to see if there's any difference and check what might be wrong with the one you're currently using.
Logged
ss
Newbie
Reply #4 on:
May 08, 2024, 04:19:47 am »
Though I tried to assign another path, the situation didn't go well.
The X Size paramator has still turned gray...
Logged
ITOOSOFT
Hero Member
Reply #5 on:
May 09, 2024, 10:26:03 am »
As mentioned previously:
"Once you link the
Spline
node, the
X Size
parameter isn't available ..."
. If you want to define it numerically, you should remove the
Spline
node from the
Spline
Input of the
Generator
Logged
ss
Newbie
Reply #6 on:
May 14, 2024, 04:47:18 am »
I made sence about X Size, thanks a lot.
Logged
Print
Pages: [
1
« previous
next »
RailClone
RailClone Lite
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
