Author Topic: Panelling and Wainscoting at the Stairs  (Read 17405 times)
michal1000
« on: December 28, 2017, 01:17:34 pm »
How can I create Wainscoting at the stairs like at that image bellow, by using the panel from that tutorilas: https://www.itoosoft.com/tutorials/creating-panelling-and-wainscoting?back=page%3D2
Re: Panelling and Wainscoting at the Stairs
« Reply #1 on: December 28, 2017, 01:55:34 pm »
On sloped paths, used Segment(s) should use the Deform > Vertical option - in this mode, the geometry stays vertical, but the vertices are moved in the Z axis to match the elevation of the path. Hope that helps.
michal1000
« Reply #2 on: January 23, 2018, 04:28:29 pm »
I've trided it and it is almost perfect but I have problem with connections. You can see it on the pictures.
