Author Topic: Curtainwall Array 2s  (Read 19069 times)
Kraiggc@dsccol.com
« on: March 05, 2025, 04:30:02 pm »
This can probably be remedied with a proper tutorial, so please link something if you have it. I've looked at videos, but none work, or are completely outdated. I've attached a file, I'm trying to create a simple curtainwall for DD purposes. I can't get the glass to fill in the "Default" gaps.
Kraiggc@dsccol.com
Re: Curtainwall Array 2s
« Reply #1 on: March 05, 2025, 04:43:35 pm »
I've created a work around, but I feel like I should be able to do all this in the Array 2s node.
« Reply #2 on: March 06, 2025, 09:49:17 am »
Hi Kraig,
You can use the A2S with Intersections macro, which automatically scales all segments as needed. This should help you set everything up properly without the hassle of manually creating the style. I've attached the modified scene (250306_DDTest_ITOOSOFT.max). I hope this helps.
