Author Topic: Number sequence starting at a specific number  (Read 633 times)
OU9561
« on: April 27, 2020, 02:35:39 AM »
Hi! I followed the locker numbers tutorial to generate a number sequence. What I'm trying to do is a time line on a floor with the years counting up, so I have 4 sequencers instead of 3. The thing is, I want the sequence to start at 1921, but can't think fo how to do it.
Also, I want the numbers to be perpendicular to the spline. I tried a transform modifier after the compose, but that just rotates each segment in place.
thanks!
Re: Number sequence starting at a specific number
« Reply #1 on: April 27, 2020, 09:20:54 AM »
I have modified tutorial files.
I could not make rc generate Geometry from 1921. I had to generate lower number items as well, I just made them a lot smaller, You can make them invisible material as well.
Hope this helps
OU9561
« Reply #2 on: April 27, 2020, 07:32:19 PM »
Hi Rokas, I0m sorry but I'm using Max 2018, could you save it as an older max version?
Also, how can i rotate the whole composed number 90 degrees?
thank you!
« Reply #3 on: April 28, 2020, 08:00:12 AM »
I have edited the style so the numbers are rotated. Hope this helps
OU9561
« Reply #4 on: April 28, 2020, 10:20:51 PM »
Thanks a lot!
« Reply #5 on: April 29, 2020, 12:18:54 AM »
Well, I think it`s about time to introduce a new Null Segment in Object section for Counting/Termination/Spacing purpose.  ;)
