Author Topic: Segment does NOT conform to surface.  (Read 87033 times)
jsanchez3d
« on: February 07, 2023, 09:33:11 pm »
Hi, I'm trying to get a segment to conform to a surface, but it only does it in the X direction and will not conform on the Y direction.
Please HELP!
Re: Segment does NOT conform to surface.
« Reply #1 on: February 08, 2023, 10:17:40 am »
Please try enabling the Align Y with Surface option in the Segment's properties. Although this doesn't deform the geometry, it will rotate the segment to follow the surfaces normals .
Cheers!
jsanchezSTV
« Reply #2 on: February 08, 2023, 09:29:14 pm »
Thank you Paul. But for some reason it's not conforming like the one running in the X direction. As you can see its not deforming in the Y direction, only in the X. Any other ideas?
jsanchezSTV
« Reply #3 on: February 08, 2023, 09:31:47 pm »
Does it have to do with the way I created the segment?
« Reply #4 on: February 09, 2023, 05:36:37 am »
Try using A2S Generator. I think I had the same issue a long time ago.
jsanchez3d
« Reply #5 on: February 09, 2023, 11:52:36 pm »
I hope there is a simple solution to this problem. I tried setting the "Align Y with surface" to no avail. There has to be a solution to why only segments drawn along the X axis conform to surfaces and segments drawn along the Y axis DO NOT conform to surface.
PLEASE HELP!
« Reply #6 on: February 10, 2023, 02:00:04 pm »
The L1S generator wasn't designed to deform on the Y axis, however you can do it with the A2S generator. Please see the attached file for an example.
Cheers!
