RailClone => RailClone Lite => Topic started by: duhast on July 04, 2013, 06:52:09 pm
when save max file and open it again,the RailClone Objects turning into a empty mesh,Because RailClone will read the MAX file's data in Library,but in the library,those MAX files was created by a old version of 3ds max,so,I open each MAX file and save again by a new version which the RailClone was installed,now,there is no problem,it's so good!
sorry for my bad English,I hope you can read it.Thanks a lot!
There are not problems using old Max versions for the library. All our libraries are created with Max 9, to keep the compatibility with all Max supported versions, and they work fine.
Usually these corruption problems are caused by using non authorized versions of RailClone Pro. Please, check your licenses.
