Toggle navigation
Login
Register
RailClone
RailClone Lite
Stairs
« previous
next »
Print
Pages: [
1
Author
Topic: Stairs (Read 18228 times)
NJ3100
Newbie
Stairs
on:
November 30, 2017, 07:25:18 pm »
hello, when i make a stair with the vertical deformation on a helix the opposite side to the spline is no flat, i think because the projection of the geometry is no evenly on this side.
in the ready file of the tutorial this get solved with a edit spline. then the segments are perfect distributed all along the stair on both sides.
but when i apply a edit spline over the helix nothing change. Can someone tell me how to fix it?
Logged
ITOOSOFT
Hero Member
Re: Stairs
Reply #1 on:
November 30, 2017, 07:30:19 pm »
Thanks for your message. The issue is that Max's helix spline has its segments set to spline. The solution therefore is to add an Edit Spline modifier, select all the segments, right-click and change them to curves.
Best,
Logged
NJ3100
Newbie
Re: Stairs
Reply #2 on:
November 30, 2017, 08:29:42 pm »
thanks a lot for the answer! The solution was like u said, but not selecting all the segments but selecting the whole spline, then right click and change to curve, now is working fine!
Thanks again and best regards!!
Logged
Print
Pages: [
1
« previous
next »
RailClone
RailClone Lite
Stairs
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
