RailClone => RailClone Lite => Topic started by: RG1597 on September 29, 2020, 05:07:38 pm
Title: VrayLightMtl on railclone objects - not emitting light properly.
Post by: RG1597 on September 29, 2020, 05:07:38 pm
VrayLightMtl produces unexpected results when applied to a Railclone object.
The firest file is the railclone object inside another one (spheres inside each room of a building)
The second is normal spheres instanced inside the rooms (railclone) with the same material applied.
Vray 5 3DSMax 2021.
Is this known behaviour? If so it's a real shame as it wouldn't allow material workflow for variable lighting inside buildings.
Title: Re: VrayLightMtl on railclone objects - not emitting light properly.
Post by: RG1597 on September 29, 2020, 05:13:08 pm
Ok, nevermind, it works going through the VrayMtl self illumination slot
Post by: IT1371 on February 03, 2021, 10:36:54 am
I experience the same issue, but with a twist.
Oddly, VrayLightMtl produces a desired effect when rendering with Vray IPR, but when switching to production render it doesn't work anymore.
Almost feel seems like Direct Illumination doesn't work anymore (like its in a multisub), since the RC object still glowing but won't light up a room.
