Author Topic: corner threshold  (Read 29553 times)
harumscarum
    • harumscarum's portfolio
corner threshold
« on: August 14, 2013, 01:11:37 pm »
hello
i'm back with one more suggestion - would be great to have 'corner threshold' value to avoid unwanted elements
here is illustration below - only marked corners where are posts are needed
Re: corner threshold
« Reply #1 on: August 14, 2013, 04:16:19 pm »
You can use Generator->Rules->Corner type to define on what type of vertex apply the Corner rule. So, set for example the vertices you want to use as "Corner", and the others to "Bezier-Corner".
Alternatively, you would use a Conditional with the "Angle" condition, to apply corners based on the angle of the spline.
http://www.itoosoft.com/railclone/reference/refoperators.php#Conditional
