Author Topic: Need to rotate RC 90 degrees  (Read 4672 times)
TL1895
« on: February 02, 2016, 03:03:56 pm »
So that it will be vertical, instead of laying flat (as pictured.)
Thanks in advance :)
TL1895
Re: Need to rotate RC 90 degrees
« Reply #1 on: February 02, 2016, 03:19:09 pm »
Hi!
If you're using clipping splines and Extend X/Y size to area the easiest way is to just Rotate the whole RailClone object so that it's local Z axis is pointing towards the wall. There's a section at the bottom of the Clipping Splines chapter of Next Steps with RailClone called "Using Extend X/Y Size to Area to create Vertical styles." that you might find helpful.
Thanks!
TL1895
« Reply #2 on: February 02, 2016, 03:47:59 pm »
Thanks Paul, I am relieved that it was something simple!
