Author Topic: Preset fencing UVW mapping error  (Read 3000 times)
JTP Vis
« on: March 19, 2019, 10:38:18 am »
I have discovered a missing UVW mapping on a fencing preset. I thought this morning I was going mad, as I couldn't at first reproduce the error, but I have discovered that it is renderer specific:
  • Set the renderer to scanline (master units=meters, but I don't know if that is critical)
  • create a railclone object and a spline for it
  • select "Architecture: Exterior: Fences: Wood: Featherboard Panels - 1.8M"
  • with the resulting railclone selected, make material id 9 visible in the viewport and you should see that where the top rail is id 9, the UVW mapping is missing
I hope someone can reproduce this problem, and find a quick solution. I have not checked any other of the UVWs as this is the only one I need.
If this can be simply fixed, how quickly can it be done? I am in need of it for a job I am doing, which needs to finish this week.
Thanks in advance,
Bill
Re: Preset fencing UVW mapping error
« Reply #1 on: March 19, 2019, 11:07:40 am »
Please uncheck "Use Instancing engine"
That fixes the problem.
JTP Vis
« Reply #2 on: March 21, 2019, 12:27:14 pm »
Hi Rokas,
I did that, but it made no difference! What exactly does that do? Should it make a difference in the viewport?
You did notice that this is specifically when using the scanline renderer and railclone set to "Automatic Selector" for materials? The probled does not occur with v-ray renderer selected.
I hope to hear back again soon.
Bill
« Reply #3 on: March 21, 2019, 01:59:53 pm »
yes. Works here with Instancing Unchecked.
JTP Vis
« Reply #4 on: March 21, 2019, 02:36:22 pm »
Hi Rokas,
Thanks for your reply. That is interesting. Followed your process, and it didn't work... until I rendered, then it fixed it. I suppose that is because the setting is a rendering instance engine setting?
Considering I only want this for an export to FBX and ultimatly to lumion, it's a bit of an odd fix, but it does indeed work. Is there not a way to fix the underlying geometry and reissue the railclone library object with it fixed? I would have thought that would be a more robust fix.
Thanks for the tips.
Bill
