Author Topic: "Randomize" node bug in RC 3.0.7  (Read 4112 times)
Anatoly
« on: July 29, 2017, 05:03:54 pm »
Hello.
1. First bug is about exporting parameters in Randomize node:
I add a "Randomize" node in style editor, then I link some segments to it, and then I want to export parameters (to control percentage of segment types from Parameters rollout), but my newly added segments are not in export list, and I can't export their "Presence" parameter. To do so, I need to close and reopen Style Editor, then they appear in export list.
2. Second, and much more serous bug is that when I link Numeric node to "Presence" parameter of "Randomize" node, it does not control anything, seems like it is simply ignored.
I Attach a simple scene which demonstrates this bug. In RailClone object there are two generators: one with "Randomize" node, where everything is in a correct logical way but not working, and the second generator with a workaround I had to do, just in case...
Thank you.
Re: "Randomize" node bug in RC 3.0.7
« Reply #1 on: July 31, 2017, 04:06:11 pm »
Big thanks for reporting it and for the provided scene. We can confirm this problem and our main developers will check it.
Best regadrs,
