RailClone => RailClone Pro (*) => Topic started by: Anatoly on July 29, 2017, 05:03:54 pm
Hello.
1. First bug is about exporting parameters in Randomize node:
I add a "Randomize" node in style editor, then I link some segments to it, and then I want to export parameters (to control percentage of segment types from Parameters rollout), but my newly added segments are not in export list, and I can't export their "Presence" parameter. To do so, I need to close and reopen Style Editor, then they appear in export list.
2. Second, and much more serous bug is that when I link Numeric node to "Presence" parameter of "Randomize" node, it does not control anything, seems like it is simply ignored.
I Attach a simple scene which demonstrates this bug. In RailClone object there are two generators: one with "Randomize" node, where everything is in a correct logical way but not working, and the second generator with a workaround I had to do, just in case...
Thank you.
Big thanks for reporting it and for the provided scene. We can confirm this problem and our main developers will check it.
Best regadrs,
