Author Topic: Forcing to Build RC object during interactive rendering (vray)  (Read 2844 times)
Makes max crash.
can You fix this?
Re: Forcing to Build RC object during interactive rendering (vray)
« Reply #1 on: July 31, 2017, 05:01:58 pm »
Thanks for reporting it. We´ll check what can be done to avoid similar issues.
Best regadrs,
« Reply #2 on: August 01, 2017, 09:32:52 am »
Fixed for the next update.
Anyway, Update action doesn't only rebuild the RailClone object, but also clears some caches and data used by the plugin.
On interactive render, this step will be omitted because may crash Max. Therefore, behaviour of "Update" button may be different, depending if IPR is running or not.
« Reply #3 on: August 01, 2017, 09:40:13 am »
...behaviour of "Update" button may be different, depending if IPR is running or not.
Thanks. Good enough, better then crash.
