Author Topic: "Y Spline Length" not working  (Read 11364 times)
Telegram71
« on: April 28, 2014, 12:38:59 pm »
I have a very simple question but I can´t get around it..
I´m trying to build something similar to the Spider Glazing Tutorial.
I have an expression to regulate the vertical count of the panel, based on the length of the vertical spline.. if I write manually on the expression the length of the Yspline everything works fine, but as soon as I use the variable YSplineLength in the espression, it doesn´t work anymore (railclone builds a geometry, but it looks like the YSplineLength = 0).
Am I missing something? Do you have any idea how I can solve the problem?
Thanks in advance! And great tool by the way! I bought it few days ago, and I´m already enjoying it a lot!
Re: "Y Spline Length" not working
« Reply #1 on: April 28, 2014, 01:33:35 pm »
When using variables and expressions it is often the case that you will need to use a transform operator instead of modifying a segments parameters directly. Trying to wire an expression to a segment will often display an error to warn you of this.
So instead wire the glass segment to a Transform operator, expose the Y Fixed Scale parameter and wire the arithmetic operator to this. You should now find your original equation including the YSplineLength variable works fine  :)
Hope that helps,
Many thanks,
« Last Edit: April 28, 2014, 01:42:48 pm by Paul Roberts »
