Author Topic: clipping area problem  (Read 4650 times)
Pierre
    • Studiosezz
« on: April 15, 2015, 05:55:04 pm »
I try to place lights on overlapping areas but I am having a problem on one of them. Can you explain me why it happens?
Thank you
Pierre
Studiosezz PARIS
www.studiosezz.com
Re: clipping area problem
« Reply #1 on: April 15, 2015, 07:07:42 pm »
Hi Pierre
Unfortunately RailClone doesn't create a unique array for each spline if they are overlapped when using Extend X/Y size to area mode. When they overlap, RailClone expects to uses splines one inside the other as alternating include-exclude areas.
This explains why you get unusual results with partially overlapped splines:
In this case, I'd recommend using Forest Pack to place the lights. To do this:
  • Convert your splines to a surface by applying a UVW modifier. If necessary open the objects properties and turn off Renderable
  • Apply a planar UVW Map modifier to the surface
  • Create a Forest object. Add the Light as a scatter item and add the floor plates object as a surface/
  • Set the Mode to UV from the Surface rollout
  • In the Distribution rollout, set the map to Full and adjust the X and Y unit values to get the correct spacing.
  • If necessary, to placement on individual ceilings you can add am Unwrap UVW modifier to the surface and adjust individual UV islands
I've attached a file demonstrating this technique.
Many thanks,
« Last Edit: April 15, 2015, 07:10:49 pm by Paul Roberts »
« Reply #2 on: April 15, 2015, 08:00:09 pm »
You could also explode Your spline by levels and use multiple A2S generators within style editor:
« Last Edit: April 15, 2015, 08:13:57 pm by Rokas »
Pixelab
  • Suave mari magno
    • pixelab.be
« Reply #3 on: April 15, 2015, 09:45:47 pm »
I love you can do the same thing with 2 different plugins. I often have to ask myself which one is the best suited !
Pierre
    • Studiosezz
« Reply #4 on: April 16, 2015, 10:09:58 am »
Thank you Chris and Rokas,
I first tried with forest but I was not satisfied with my result :) And I also thought of detaching the splines but it's a bit more laborious soon as there is a lot of floor.
Anyway thank you again,  I managed thanks to you.
Pierre
Studiosezz PARIS
www.studiosezz.com
