Author Topic: arithmetic (substract) issue  (Read 4807 times)
harumscarum
    • harumscarum's portfolio
« on: May 15, 2015, 02:00:07 pm »
there is arithmetic issue when i try to substract Y size (attribute) from Z size (parameter) so i need to multiply it by (-1) first and then use add instead substract
scene is attached
Re: arithmetic (substract) issue
« Reply #1 on: May 15, 2015, 02:57:54 pm »
i get the same bug:
exported attributes do not get their value if they are not first node in arithmetic operator.
« Reply #2 on: May 15, 2015, 03:06:56 pm »
Thanks to both of you for reporting this,  I get the same results too. we'll look into it.
Many thanks,
