Author Topic: [Solved] 2 questions on a railing object & empty objects  (Read 7891 times)
Pixelab
  • Suave mari magno
    • pixelab.be
« on: June 20, 2015, 01:55:10 pm »
Here attached a railing that finally looks like I wanted to. Looks really good in render, but I want to improve a bit the object for special situations and eventually make the style more "elegant"
Also, thanks for the new general padding parameter / segment, It really helps to simplify in those situations !
First question :
I've added a "spacer object" to move the 2 glass panels apart on the corners and on the evenly spearation. Problem is that I had to do it with a "spacer" obect (a simple tiny plane you can see under the corner) and I was wondering if there is a more elegant way to style this. I tried with a padded default empty segment but it somehow doesn't work and messes up the padding of adjacent object. I neither wasn't able to "center" the spacer on the corner.
Second question : Is it a way to prevent the posts to appear on short segements of the spline, like those 2 posts. Either remove the 2 posts, or make it one centered. This might involve some conditional parameters but I don't know where to start nor to look at in the help files.
« Last Edit: June 23, 2015, 10:44:27 am by Pixelab »
Re: 2 questions on a railing object
« Reply #1 on: June 20, 2015, 02:43:52 pm »
1st problem- i did what You tried, and managed to do without any problems.
2nd- I went with assigning mtl id=2 to short spline segment and limiting posts to mtl id= 1.
« Reply #2 on: June 21, 2015, 09:41:46 am »
Thanks for your help, Rokas.
Initially, the second problem would be solved with a Conditional node, based on the length of the spline's section (a section is the path between two Corner or Evenly points).
But since corners are placed between two sections, there is not any condition that we can use. We should need some kind of "Next-Section", "Previous-Section" conditions specific for corners.
I added this improvement to our to-do list for next updates.
Pixelab
  • Suave mari magno
    • pixelab.be
« Reply #3 on: June 22, 2015, 03:21:28 pm »
Thanks Rokas & Carlos for you answers !
1- Rokas, Could you upload the file in max 2011 ? I've tried again and failed again >_< thx a bunch for checking this out
2- Assigning another Id is indeed the workaround I've found, and yes, after some attempts with the conditional operator, I've noticed that the "current section" doesn't work well with corner segments. "Next-Section" or "Previous-Section" would be great, as long as it doesn't complicate the object too much ;)
« Reply #4 on: June 22, 2015, 03:28:15 pm »
sure, BTW, don`t You mind me borrowing this style in my future projects ;) ?
Pixelab
  • Suave mari magno
    • pixelab.be
« Reply #5 on: June 22, 2015, 04:53:01 pm »
You're welcome  :P
I saw that you did put "alignment right" for the empty spacer object and a transfrom/ padding right to solve the problem. Still wondering why this has to be so complicated but thanks for the solution !
« Last Edit: June 22, 2015, 10:56:18 pm by Pixelab »
« Reply #6 on: June 23, 2015, 10:28:26 am »
I must explain this. In RailClone 2.2.1 we fixed a bug related with the size of empty segments. Copied from the release notes:
- Fixed: length of Left Padding on empty segments is double as intended.
  Note: to keep compatibility with existing scenes, this fix is applied only in styles created with v.2.2.1 or above.
All RC objects created with RC 2.2.0 and before work in the old way (with the bug). You can check if the fix is being applied or not using Maxscript:
$.createdversion
If this value is 221 (from RC 2.2.1) or greater, the padding of empty segments is computed correctly.
So, in this case you could use an empty segment with Left + Right padding, or alternatively using "Fixed Size", and it will be centered correctly.
To "upgrade" an old RC object, just update the parameter:
$.createdversion = 250 (or any other value greater than 220).
Hope i have clarified this issue.
Pixelab
  • Suave mari magno
    • pixelab.be
« Reply #7 on: June 23, 2015, 10:38:38 am »
$.createdversion
WOW, that just fixed everything and now it works like intended. I was about to request a new sizable empty object, because it's way easier and the node graph is easier to understand than using padding. Fixed size empty elements are really useful.
Whats strange is that when I type the commands in the listener, It returned 0, is it normal ?
Code: [Select]
$.createdversion
0
250
Do I have to do on every RC object, or new ones will be good ?
Thanks a lot !
« Last Edit: June 23, 2015, 10:42:13 am by Pixelab »
« Reply #8 on: June 23, 2015, 02:20:37 pm »
Yes, that's normal for objects created before v.2.2.1 because this parameter was not implemented. So it returns 0 as default value.
No, it's not necessary. For new objects it's intialized to 250 (or the version which they have been created).
