Author Topic: Railclone slow? Vray 3  (Read 20164 times)
Re: Railclone slow? Vray 3
« Reply #15 on: July 30, 2014, 12:00:26 am »
Hi Rokas,
You should be able to just rotate the whole object so that the y axis point toward the slope and then reselect the spline,  but that looks correct to me.  Because the array now starts from the bottom not the top you will need to change the angle of the tile segments so that they overlap correctly.
Paul.
« Reply #16 on: July 30, 2014, 07:13:30 am »
I believe roofing deserves separate tutorial, and some styles, please ;)
DT
« Reply #17 on: July 30, 2014, 11:46:49 am »
Thank you very much for the explanation. I have succesfully edited the roof. It looks exactly like I want now.
(you don't need to rotate the pivot but you need to rotate your RC object with the local axis to see where the Y axis are)
