Author Topic: 2.2.3 Display as mesh issue  (Read 10971 times)
IT1371
« on: April 02, 2014, 10:52:00 am »
I was unable to tick the option display as mesh in viewport at railroad models.
They just disappear from viewport, but render just fine.
I needed it to convert to poly in order to export to sketchup so anyway I used Railclone Tools to do that.
Re: 2.2.3 Display as mesh issue
« Reply #1 on: April 02, 2014, 12:01:24 pm »
When using Display as Mesh the number of segments and polygons that can be displayed in the viewports are defined by the Display->Limits values. If the numbers exceed these values RailClone will simply display the RC icon, but as you described it should render fine. It is possible to increase these values but RailClone tools is preferable in most cases as it will create instances to help improve memory usage.
Hope that helps,
Many thanks,
« Last Edit: April 02, 2014, 12:03:19 pm by Paul Roberts »
IT1371
« Reply #2 on: April 02, 2014, 01:53:11 pm »
Thanks! worked well :)
