Author Topic: reducing segments on objects such as sidewalks and curbs  (Read 3690 times)
mitviz
    • mitviz
« on: April 19, 2016, 02:13:47 pm »
as you can see this is maybe overkill, is there a way to reduce the segments not needed?
Professional architectural renders
Re: reducing segments on objects such as sidewalks and curbs
« Reply #1 on: April 19, 2016, 02:24:51 pm »
Thanks for the feedback. The geometry is subdivided to allow it bend around corners smoothly , but you could create a conditional relationship based on Spline IDs that tells RC to use the high poly object for curves and the low poly object for straight sections. This would be especially important if you're exporting the geometry to a real-time engine. Otherwise, the high poly count shouldn't be a big problem because RailClone instances any segment that is not deformed or sliced, so really the rendering overhead is very low.
If you want to know more about conditional rules in RailClone then the Creating Conditional Relationships chapter in the Next Steps with RailClone guide might be useful,
Many Thanks,
mitviz
    • mitviz
« Reply #2 on: April 19, 2016, 02:26:24 pm »
aha, nice!
