Author Topic: Curb style - please can you help me  (Read 4696 times)
MH4288
« on: October 06, 2018, 09:18:33 pm »
I tried to make very simple curb style, but cant make it to work. I made it as a simple middle part, evenly part with space and corner part. On picture corner part looks good, but only on this place, on other corners it looks terrible. How can I do this please?
And one more thing. It will be great when corner part will work on a different angles, not only 90. But for start, it will be great to work at least on 90 :-)
Thank you.
« Last Edit: October 06, 2018, 09:20:36 pm by MH4288 »
Evgeniy_Ivanov
Re: Curb style - please can you help me
« Reply #1 on: October 06, 2018, 10:21:47 pm »
Thank you.
http://prntscr.com/l3061k
You can use this as an example. Hope it helps.
MH4288
« Reply #2 on: October 06, 2018, 10:58:23 pm »
Nevermind, I found a solution already, now its ok. But I have a different problem with changes in slope. RC puts corner part but I need evenly part instead. Is this possible or how can I achieve that?
Thank you.
« Last Edit: October 06, 2018, 11:00:51 pm by MH4288 »
Evgeniy_Ivanov
« Reply #3 on: October 07, 2018, 03:48:46 am »
Thank you.
Im not an expert, but I think you should disconnect corner and put evenly instead:-)
« Reply #4 on: October 07, 2018, 08:43:29 am »
Please upload Your styles in max file. This way You will get faster help and more accurate- according to Your uploaded file, not just some theoretical suggestion.
MH4288
« Reply #5 on: October 07, 2018, 05:00:18 pm »
I am sorry, I fix that already :-)
Now I have last problem. Evenly part is placed exactly in distance I set. That is ok, but when I place vertex somewhere, evenly part is not right on in but respect evenly distance I set. Can I put higher priority on vertex positions and after that use evenly distance?
Thank you.
« Reply #6 on: October 07, 2018, 07:44:59 pm »
No, You can't define higher priority vertices.
Please better explain what You want to create.
MH4288
« Reply #7 on: October 07, 2018, 09:02:06 pm »
As I said in first post, it should be a curb style around a sidewalk. Its ok, but when there are a stairs, I have to move vertexes up or down. Vertexes are exactly where stairs start and end. But RC respect evenly distance, so curb will be in a ground or in the air. I hope it is understandable.
« Reply #8 on: October 08, 2018, 08:51:42 am »
I want to make sure You understand what Evenly does. It creates evenly spaced segments on Shape segments (not whole Spline).
I would highly recommend following these tutorials: Next Steps With RailClone for better in depth knowledge of the plugin.
MH4288
« Reply #9 on: October 08, 2018, 10:02:03 am »
I know what evenly does. I asked for something I dont know how to do. If its possible achieve somehow.
« Reply #10 on: October 08, 2018, 10:08:12 am »
