Author Topic: 2D array with specific repetition  (Read 5315 times)
narsov
    • narsov.com
« on: November 10, 2016, 09:00:49 pm »
I am trying couple of days to achieve the repetition in colors with 2d array (see image), but I cant get the final result. Some help, directions would be nice.
Narsov
« Last Edit: November 10, 2016, 09:46:04 pm by TF6996 »
Re: 2D array with specific repetition
« Reply #1 on: November 11, 2016, 05:23:23 pm »
To build this style, I would suggest you to use the Sequence Operator in the Increment at X mode for each row and these wire into another Sequence Operator - this time in the Increment in Y mode. Each Segment can be linked to multiple Material Operators to Replace its Material ID correspondingly and get desired pattern. Attaching a sample scene, please feel free to simplify the Multi/Sub-Object material, as this has been used just for testing purposes and total number of IDs can be lowered. Hope you'll find it useful.
narsov
    • narsov.com
« Reply #2 on: November 16, 2016, 08:37:27 am »
Thanks for the help, it works great. I have additional question, how to make continuous on larger surfaces? It can be randomly scattered.
 I have attached the file and an example. Thank you.
Narsov
« Last Edit: November 16, 2016, 08:39:24 am by TF6996 »
« Reply #3 on: November 16, 2016, 12:54:02 pm »
There are several ways how add randomness to such style. Probably the easiest way would be to enable on involved Segments the Transform - Random - Scale (in attached sample scene I've limited it to 80% - 120%). For further randomization, please feel free to experiment with the Randomize Operator.
I would suggest you to check the "Creating randomised books" / "Randomising Blinds" tutorial. Hope you'll find them interesting and helpful.
