Author Topic: 2s array Y default...  (Read 4276 times)
Troy_1234
« on: June 23, 2021, 07:53:10 pm »
I'm looking to create a 2s array for a facade, I would like the Y evenly to ignore the X evenly, or maybe it should be a Y default(?)- so I can scale geometry as a horizontal band.
Not sure if this makes any sense, but here's some pictures to help describe. Picture of the facade I want to create and picture of where I've got to!
Also, is there a way to display the base geometry colour, rather than the whole railclone as one colour?
Re: 2s array Y default...
« Reply #1 on: June 25, 2021, 07:52:56 am »
Hi.
I would consider this as one floor:
Try to make what is in green marking in one linear generator first. Then use another linear to distribute across the floors. That is what I would try first.
I would not use y evenly in this style (now i think so)
You can display Geometry color, just assign RailClone the same material You use for Your segments.
