Author Topic: Complex Mesh breaks on a simple Array1S  (Read 10304 times)
OU9561
« on: September 17, 2024, 04:06:38 am »
Hello! I'm trying to build this sofas using a simple Array 1S with a spline and one element:
The problem I'm having is that on the curves the mesh get completly broken, and I'm also having trouble getting the segments to be of similar widths:
I've applied a retopology modifier to see if that was the issue but the problem persists:
Any help is greatly appreciated!
Re: Complex Mesh breaks on a simple Array1S
« Reply #1 on: September 17, 2024, 11:06:17 am »
Increasing the Style > Geometry > Curve Steps value resolves the issue. Additionally, I recommend using Adaptive Mode instead of Tiles for this scenario, and the Start and End inputs are not necessary. Please find the modified version (240917_Sofas_ITOOSOFT.max) of your scene attached.
I hope this helps!
OU9561
« Reply #2 on: September 17, 2024, 03:47:51 pm »
That's perfect, thank you very much!
