Author Topic: 3DS Max 2020 Quad Menu Items Missing  (Read 3693 times)
Bruce Hart
« on: January 14, 2020, 12:52:57 am »
Hey guys
I have a network deployment install for RailClone 4 in my office.  For some reason I don't get the quad menu items registering in my Max 2020 install (Select Base Object etc).  It does work properly in the Max 2018 version however.  I've tried reinstalling but no luck.  Any thoughts as to why this could be happening or how to fix it?
Cheers
Re: 3DS Max 2020 Quad Menu Items Missing
« Reply #1 on: January 14, 2020, 08:21:56 am »
Do You have these files after install:
%Localappdata%\Autodesk\3dsmax\2020- 64bit\ENU\usermacros
Does RC work fine apart from these quad menu items?
Bruce Hart
« Reply #2 on: January 15, 2020, 02:14:27 am »
Hi Rokas
yes those scripts are in that folder and RailClone does work properly.  I have an install of Max 2020 & Railclone at home and the quad menus work fine.
.....OK I've realised I had the Load Startup Scripts Option disabled in my preferences and that was the issue.  I would not have tracked down the problem without your pointer, so thanks for your help.
Cheers
« Last Edit: January 15, 2020, 02:39:53 am by Bruce Hart »
« Reply #3 on: January 15, 2020, 09:33:10 am »
Thanks for sharing the solution. It might be helpful in future.
