Author Topic: corrugated sheet metal  (Read 2687 times)
JI5496
« on: January 14, 2020, 06:58:54 pm »
I am trying to create the attached image as a railclone object. (cs.jpg)
I basically need 2 different versions. The first, a simple panel, I managed to do myself. (red object in screenshot)
The second version, where the pattern is following the spline, especially the corner section (like in the picture) I have some trouble with.
I managed to put something together (top blue object in the screenshot) but it only works if the spline has the right size. When I change it, it falls apart.
Whats the best way to achieve this?
Any help would be appreciated.
Thanks!
« Last Edit: January 14, 2020, 10:44:23 pm by JI5496 »
Re: corrugated sheet metal
« Reply #1 on: January 14, 2020, 07:25:03 pm »
Please, can you downgrade Max file to 2018?
JI5496
« Reply #2 on: January 14, 2020, 10:45:00 pm »
just updated the main post!
« Reply #3 on: January 16, 2020, 12:53:25 am »
Hi, sorry for the delay. I had some deadline  :(
Here is one possible solution. The generator is driven by Single Spline and Z Height Parameter.
This is just a quick setup and needs some tweaking to set up everything to match.  ;)
If your workflow dictates a Closed Spline solution or any other  I can rearrange initial RC for you,
Best Regards
« Last Edit: January 16, 2020, 07:20:53 am by Dragan »
