Author Topic: Is there an Auto Align to Spline alternative for 1S Array or expression  (Read 3525 times)
RC2292
Hopefully a quick answer.
It's been a while so maybe there's a way of doing this now. Couldn't see anything in the forums about it.
Want to align an 1S array based on the spline rather than Generator
Hm, not sure I undertand. Can you please elaborate more or share a Max scene?
RC2292
Hi Dragan, thanks for looking at this and sorry I wasn't very clear.
Attached the file but I'm after a way of offsetting an 1S Generator using the local spline coordinates like you can for a 2S by checking the 'Auto Align to spline'.
Let me know if that makes more sense.
« Last Edit: April 10, 2021, 05:09:34 pm by RC2292 »
Please downgrade the Max file to 2018 (and make that as default when you posting to the forum so more people can open the file)
RC2292
Just added.
If you want to "fit" segments into a rectangle border as A2S you can`t because L1S is basically `follow the path` array so RC does not see this spline as closed when using L1S.
In this particular case, you can select Transform node and set Alignment for Y to Bottom.
« Last Edit: April 10, 2021, 06:25:45 pm by Dragan »
RC2292
Thanks for the prompt reply Dragan.
No sorry, I don't think I'm explaining it very well.
basically want both the 2S and 1S versions to be identical and offset to the local spline Z not the Generator Z.
Just wasn't sure if there was a cheat somehow?
Does this help?
I got you now  :D
Orientation of the RC icon should be on XY plane.
After that just reverse subspline.
RC2292
Aw man! was it really that simple!!  :-[
Thank you
