Author Topic: Randomizing sequences  (Read 4928 times)
Adi S
« on: October 22, 2020, 01:07:03 am »
I'm wondering if it's possible to make a randomization of repeating row of Segments, in a single Generator and on single Spline? For example , I want to make a row of 3 types of bottles and each bottle is grouped with 5 copies in a row. That row would be one Segment and I'd like to Randomize it . But I'm not sure on how to make it.
I tried using Sequence Operator with single Segment unsuccessfully. I added single geometry Segment into Sequence, followed by Null Segment with fixed size, for space between bottles. Randomize node just ignores Segment node and randomizes all sub-segments separately.
Right now the only solution I can think of is making separate Generators for each of the bottles distributed on a spline and nest them in the Main Generator or simply making multiple bottles as one Edit Poly object.
Re: Randomizing sequences
« Reply #1 on: October 22, 2020, 08:06:52 am »
for such styles it is advisable to use Nested generators workflow. Easy to understand and modify.
Hope this helps
Adi S
« Reply #2 on: October 22, 2020, 10:07:45 am »
Hi Rokas , you nailed it ! I totally missed this X Size property in the Generator options.
Thank you very much.
