Author Topic: L1S - Open & Closed spline problem  (Read 4449 times)
« on: June 11, 2019, 05:28:40 pm »
Closed splines are generated ok but open splines are wrong. The simple reverse is not working.
Is this job for A2S/Auto align X>XY and full closed spline with some condition for the empty bottoms?
Thank you.
Re: L1S - Open & Closed spline problem
« Reply #1 on: June 12, 2019, 09:19:27 am »
Seems like You can close the spline and assign mtl id = 2 plus restrict style to work only on mtl id = 1
« Reply #2 on: June 12, 2019, 09:55:51 am »
Thank you Rokas.
Yes, eventually that was my solution too, although I still have problems when only 2 part of the spline is active. I have started with this idea with A2S and an extra Corner segment but then I try this approach on L1S and it worked.
But what causes that kind of behaviour?
My workflow is the main modelling done in CAD software and imported into MAX. So I kinda have to extract Splines from the model and going through all and do extra connecting some time will be a pain in the ***
« Last Edit: June 12, 2019, 10:21:04 am by Dragan »
« Reply #3 on: June 12, 2019, 10:25:44 am »
Please try to do some more testing about that matter...
I have finished the job by post-sub-editing but after all, this is a simple L1S generator and it should work fine. I have tried with some rotation/alignment of RC/Segment etc. but I always get some unexpected results.
tnx
« Last Edit: June 12, 2019, 10:28:17 am by Dragan »
« Reply #4 on: June 12, 2019, 11:09:43 am »
Alternative solution (not ideal) would be to use different RC objects for different walls:
« Reply #5 on: June 12, 2019, 11:13:33 am »
Yes, I guess so...
Thank you Rokas.
Maybe we will find some ease solution with RC4....
Maybe to have some Expression or Conditional operator to detect spline/vector orientation on Global X/Y/Z.
« Last Edit: June 12, 2019, 11:17:18 am by Dragan »
