		RailClone => RailClone Pro (*) => Topic started by: muoto on October 27, 2019, 02:35:38 pm
				When editing a material while IPR mode is on and rendering a railclone object leads to max crashes
Which version of Vray/RailClone are You using? Is it consistent or random crashing?
If possible, please send us the minidump (https://forum.itoosoft.com/faq/getting-the-max-minidump-file/) when Max crashes or better a minimal max scene and steps how to reproduce the crash. It would be most helpful to find the problem.
				I have observed this also.
Here's a link to a Video capture:  https://www.dropbox.com/s/fi63qcj5ie5fus5/RailClone_Vray_IPR_1.mp4?dl=0
In this case the crash occurs when "use segment material" is checked.  I'm using 3DS max 2020.2, Vray Next 4.10.03.   I initially saw this occur with RailClone 4.09, but 4.1 has the same issue.  Also of note in the video - the Railclone object disappears.  You will also note that the crash does not occur immediately, but after several adjustments of the material.   Max file attached.
Hope this helps
