Author Topic: 4.0.9 Hard Crash on any spinner change  (Read 3477 times)
PI4914
« on: October 28, 2019, 03:08:15 pm »
I've been having a very consistent issue since updating to 4.0.9; in any scene if I create a node that has a spinner and attempt to grip the spinner and drag up and down it will almost immediately hard crash max. No error, no autodesk popup; it behaves as if I manually closed max.
I have a feeling it might be hardware related since it seems that I'm only getting this issue on Ryzen workstations (SMT Disabled).
Hardware: AMD Ryzen TR 1950X + 64GB Ram + GTX 1080ti
Software: Win10 + Max 2020 + Corona 4
Sidenotes:
I have tried this in a fresh scene and still get this crash so I do mean any scene.
The non Ryzen station that I tested and didn't have the same crash has dual Intel Xeon E5-2630 v4 processors.
As I mentioned above, our Ryzen stations have the SMT feature disabled so I will have to test with this enabled.
Cheers,
Re: 4.0.9 Hard Crash on any spinner change
« Reply #1 on: October 28, 2019, 03:13:08 pm »
I have AMD Ryzen TR 1950X  and SMT is on. I do not get these crashes.
Thanks in advance for any further comments on this issue you can share with us / our user community (in case some user(s) will run into similar troubles).
PI4914
« Reply #2 on: October 28, 2019, 05:49:40 pm »
I tested the Ryzen system with SMT enabled and still get the same crash; I'll try to continue troubleshooting this though.
DT
« Reply #3 on: January 10, 2020, 11:35:02 am »
Same problem here on my older workstation (Dual xeon) and my new workstation (threadipper 3970x). With older versions of railclone and the latest as well. I experience crashes in 75% of the time when I use the spinners.
It's an immediate crash, but I do get the popup from autodesk.
« Reply #4 on: January 10, 2020, 12:30:43 pm »
We will patch spinners issue in next RailClone update. Hopefully this will work better.
