RailClone => RailClone Pro (*) => Topic started by: PI4914 on October 28, 2019, 03:08:15 pm
I've been having a very consistent issue since updating to 4.0.9; in any scene if I create a node that has a spinner and attempt to grip the spinner and drag up and down it will almost immediately hard crash max. No error, no autodesk popup; it behaves as if I manually closed max.
I have a feeling it might be hardware related since it seems that I'm only getting this issue on Ryzen workstations (SMT Disabled).
Hardware: AMD Ryzen TR 1950X + 64GB Ram + GTX 1080ti
Software: Win10 + Max 2020 + Corona 4
Sidenotes:
I have tried this in a fresh scene and still get this crash so I do mean any scene.
The non Ryzen station that I tested and didn't have the same crash has dual Intel Xeon E5-2630 v4 processors.
As I mentioned above, our Ryzen stations have the SMT feature disabled so I will have to test with this enabled.
I have AMD Ryzen TR 1950X and SMT is on. I do not get these crashes.
Thanks in advance for any further comments on this issue you can share with us / our user community (in case some user(s) will run into similar troubles).
I tested the Ryzen system with SMT enabled and still get the same crash; I'll try to continue troubleshooting this though.
Same problem here on my older workstation (Dual xeon) and my new workstation (threadipper 3970x). With older versions of railclone and the latest as well. I experience crashes in 75% of the time when I use the spinners.
It's an immediate crash, but I do get the popup from autodesk.
We will patch spinners issue in next RailClone update. Hopefully this will work better.
