Author Topic: Clipping not working  (Read 2682 times)
RealViz
    • RealViz
« on: April 14, 2022, 10:54:15 am »
I'm trying to create a very basic trellis using a simple RC. Unfortunately the clipping is not correct. More in attachments. Am I doing something wrong?
RealViz
    • RealViz
Re: Clipping not working
« Reply #1 on: April 14, 2022, 10:57:49 am »
When I put the UVW Map modifier on the spline (converts to polygons) everything works and the RC still holds the polygon as a spline.
« Reply #2 on: April 14, 2022, 11:02:11 am »
If you reset the Spline Xform it fixes it. Generally you'll get more predictable results if you do this to clipping splines.
I hope that helps,
