Author Topic: border flagging/Pavement Corner Problem  (Read 2766 times)
CK-Mini
« on: January 18, 2017, 11:34:49 am »
I really tried to find a way for my own pavement, but after 5 hours of trying I gave up.
Is there an easy way in Railclone for this kind of pavement? (RC_Picture_01.jpg)
From far away it looks okay, but if you see the closeup, you can see the problem in the corners. (RC_Picture_comp.jpg / upper part)
In the Picture (RC_Picture_comp.jpg / second part) you can see that if I break the spline and move it by hand, I nearly get the result I want. It would be perfect if I do not need to break the spline, because there are many more areas where i need welded splines.
My first approach was to find a similar preset from the Library Browser but I couldn't find something that I can use for my Pavement.
I attached the Max2017 file. Perhaps this help a little bit.
It would be very great if somebody can help me or give me some hint.
Carsten
Re: border flagging/Pavement Corner Problem
« Reply #1 on: January 18, 2017, 01:15:23 pm »
Disabling bevelling under Rules - Corner - Bevel Mode > None would be recommendable in this case. Instead of Transform - Translation on Y axis for these Segments, using the General - Geometry - Y Offset should give better results. To better solve Corners, adding an empty Segment should help. Attaching modified scene. Hope you'll find it useful.
Best regadrs,
harumscarum
    • harumscarum's portfolio
« Reply #2 on: January 18, 2017, 02:31:03 pm »
Wow! is iy possible to make RC window semi-transparent?
« Reply #3 on: January 18, 2017, 03:32:55 pm »
I'm afraid not, I've superposed "source two images" in the graphic editor.
Best regadrs,
CK-Mini
« Reply #4 on: January 18, 2017, 05:41:32 pm »
Wow.
Thank you so much. This looks way better. I really don't understand why an empty segment in the corner slot works in this case, but its working... :-).
Thanks for this great support
