Author Topic: Simple Flooring array will not work  (Read 12446 times)
MartinMHulse
« on: January 16, 2025, 04:40:37 pm »
Hi I had been struggling to get some rail clone cladding to work so went back to basic tutorial only to find it will not build the most simple Parquet floor?
I followed the tutorial to the letter and it will not display as shown on the video, sequence increment is at Y, Conditional is set to segment X which are the only steps I might have missed but it is not correct?
See image my build on the left, tutorial on the right.
Re: Simple Flooring array will not work
« Reply #1 on: January 17, 2025, 08:30:00 am »
Hi Martin,
You should connect the full-length segment to the FALSE input of the Conditional Operator instead of the half-length one. This change should fix it. Alternatively, you can bypass the Conditional Operator entirely by wiring the Sequence Operator to the Start input of the generator and the full-length segment to the Default input.
