Author Topic: Duct corner problem  (Read 40727 times)
PixelJockey
Duct corner problem
« on: July 20, 2013, 08:22:47 am »
I'm using the Cylindrical Duct from the RC2 library, but the corners don't look like the pretty thumbnail. The spline is a standard Max rectangle with a corner radius of 0. I have also tried to convert the rectangle to a spline and weld the verts, it still produces the same result. I haven't touched the RC setting. It does this in any file. Pipe 1 and Rectangular Duct work fine. Cylindrical Duct is the only problem preset in the Ducting library.
The attached image shows the resulting model and preset I'm referring to.
RC2 2.0.4
Max 2012 64bit
Windows 7 64bit
Intel i7-2600K
« Last Edit: July 20, 2013, 08:29:09 am by PixelJockey »
Re: Duct corner problem
« Reply #1 on: July 20, 2013, 10:11:55 am »
There was a problem in the corner segment of this preset.
I've fixed it, please unzip and copy the attached file at C:\Program Files (x86)\Itoo Software\RailClone Pro\lib\default1\Industrial\Ducting.
PixelJockey
« Reply #2 on: July 20, 2013, 10:52:12 am »
Awesome would be an understatement to describe Itoo's customer service. You rock!
