Author Topic: Paths lost  (Read 10693 times)
Macker
Paths lost
« on: June 17, 2024, 12:04:25 pm »
Hi all,
3DS max has just done it's party trick and reset all of the user/system paths back to their default.
Adding a forest pro object in the scene seems to have re-added the forest pack paths, however the same cannot be said for railclone. I've tried re-installing railclone but have had no luck. How can I re-path railclone?
Also need to do the same with vray... *sigh*.
Re: Paths lost
« Reply #1 on: June 17, 2024, 12:14:18 pm »
You might have previously marked the 'Do not show this message again' checkbox to disable the pop-up window. You can revert it to its default setting (to show the pop-up) by setting CheckTexturePath = 1 in the following system registry key:
[HKEY_CURRENT_USER\Software\Itoo Software\RailClone Pro]
Optionally, you can use the attached file (RC_CheckPaths.reg) to restore it.
It's checking folders specified in the following registry key;
[HKEY_CURRENT_USER\Software\Itoo Software\RailClone Pro\TexturePaths]
These paths should appear in the 3ds Max settings in the 3dsmax.ini file. By default it is in:
C:\Users\<yourUsername>\AppData\Local\Autodesk\3dsMax\<max version>\enu\3dsmax.ini
