Author Topic: A2S Extended - Z offset  (Read 3597 times)
« on: July 05, 2022, 11:43:34 am »
When A2S works as Extended X/Y on X-XY mode the Y offset and Z offset work in the same direction. I know why is this happening, we discussed it during the betas. Although it is an easy fix to add one Transform Operator, it would be nice to have it fixed.
Regards
Re: A2S Extended - Z offset
« Reply #1 on: July 06, 2022, 09:27:37 am »
Thanks for the reminder. Added to out list!
Cheers,
« Reply #2 on: July 06, 2022, 10:25:10 am »
Fixed for next update.
« Reply #3 on: July 14, 2022, 11:51:24 pm »
Hm, maybe to check L1S for the same issue when General X rotate=90.
« Reply #4 on: July 15, 2022, 12:24:33 pm »
Seems OK to me. The Z and Y axis remains in relation to the spline on a rotated array, but as I recall that was a deliberate decision.
« Reply #5 on: July 15, 2022, 01:19:33 pm »
As I see now (5.2.6) Y offset remains distant from the spline but the Z offset will rotate around the Segment`s Pivot.
I set the viewport rendering thickness to the Spline for a better view.
Check the left view:
Y offset=0
Z offfset=10
change X rotation
I understand how and why it works like that but from my experience, it always gives me unwanted results.  :-\
