Author Topic: How do I add custom made RailClones?  (Read 2444 times)
EndlessX
« on: February 15, 2022, 07:27:28 am »
I downloaded MegaStairs off of cg procedurals. I was wondering if anyone knows how to install it so I can use it? I didn't see it under sticky.
Re: How do I add custom made RailClones?
« Reply #1 on: February 15, 2022, 09:07:09 am »
This is not an Itoo product so I guess they don`t provide support for it.
I guess you'll have to figure it out for yourself or to contact the creator of those RC Objects.
If you just want to create a Library Item here is the tutorial for ForestPack. Though this tutorial focuses on Forest Pack, most of the techniques are equally applicable to creating libraries for RailClone.
https://www.itoosoft.com/tutorials/creating-libraries
note: New FP7 has more improvements on creating Library Items: https://www.itoosoft.com/tutorials/how-to-add-items-to-the-forest-pack-7-library
« Last Edit: February 15, 2022, 09:13:47 am by Dragan »
« Reply #2 on: February 15, 2022, 09:14:59 am »
As Dragan has mentioned, this is a 3rd party library and any support requests should be directed to them. On the other hand if it's just a case of needing to add a Max file that contains a RailClone object to the library, then you might find our documentation on the matter useful. https://docs.itoosoft.com/railclone/next-steps-with-railclone/10-creating-presets
I hope that helps,
