Author Topic: Corners not mitering properly  (Read 2655 times)
georgec
« on: December 20, 2022, 04:51:47 pm »
See attached. Outside corners of crown moulding not at 90 deg. Having same problem with base mould. Haven't had this issue before.
Re: Corners not mitering properly
« Reply #1 on: December 21, 2022, 09:56:48 am »
As I can see, the Bevel Mode in your scene was set to None  - setting it to any other will “enable it”. Also, for this kind of task, you might find a more useful the Scale mode – to keep the poly-count low. Please find the modified scene attached.
georgec
« Reply #2 on: December 21, 2022, 09:38:02 pm »
Thank you!
