Author Topic: A2S Y spline issue  (Read 3778 times)
harumscarum
    • harumscarum's portfolio
A2S Y spline issue
« on: December 20, 2015, 04:18:18 pm »
I'm about to model brick wall integrally formed with the roof so try to use single Y spline for wall and roof
Is it only one solution to flip X and Y Splines to achieve that? it is quite confusing then and doesn't allow Random Scale by X
« Last Edit: December 20, 2015, 04:26:34 pm by harumscarum »
Re: A2S Y spline issue
« Reply #1 on: December 21, 2015, 10:10:48 am »
In order to use the Y spline in this way you need to pay attention to its local coordinate system. The Y spline uses the path's local Y axis for the height or the array and the X axis to deform the path. The Z axis is ignored.
This means that if you create the spline in the front viewport you may not get the results you're after unless you rotate the spline by 90 degrees. The easiest way to ensure the spline aligns correctly is to create it in the Right viewport or create it in the top or perspective view and rotate it into position.
I hope that helps, please let me know if you have other questions.
Many thanks!
« Last Edit: December 21, 2015, 10:12:20 am by Paul Roberts »
