Toggle navigation
Login
Register
RailClone
RailClone Pro (*)
About UV
« previous
next »
Print
Pages: [
1
Author
Topic: About UV (Read 3723 times)
SL7359
Jr. Member
About UV
on:
August 01, 2022, 11:51:36 am »
For UV, the results are different when rendered with V-RayGPU and when rendered with V-RayCPU.
Where can I find the cause of these differences?
Is it possible to match the CPU results?
Last Edit: August 01, 2022, 11:56:46 am by SL7359
Logged
OakCorp Japan
Yuji Yamauchi
3dsMax[Latest]/Geforce GTX 1080/Windows10 Pro/ V-Ray for Max[Latest]/GrowFX[Latest]
Hero Member
Re: About UV
Reply #1 on:
August 01, 2022, 12:28:17 pm »
Try to turn off the instancing engine.
Logged
Administrator
Hero Member
Re: About UV
Reply #2 on:
August 01, 2022, 01:09:27 pm »
That's it. For V-Ray CPU we can generate and modify UVs of instances at render time.
But this is not possible for other renderers (including V-Ray GPU), because the engine is not open for third-party plugins.
Logged
SL7359
Jr. Member
Re: About UV
Reply #3 on:
August 01, 2022, 01:31:39 pm »
Thank you for your response. Resolved.
It is a different scene, but when I disable the instance engine, the textures are not reflected.
What could be the cause of this?
Logged
OakCorp Japan
Yuji Yamauchi
Administrator
Hero Member
Re: About UV
Reply #4 on:
August 02, 2022, 09:00:18 am »
You must apply the material to the RC object.
'Use Segment Material' has no effect when instancing engine is disabled.
Basically when instancing is off, RC generates a standard mesh, as any other Max object (which needs some material).
Logged
SL7359
Jr. Member
Re: About UV
Reply #5 on:
August 02, 2022, 09:15:54 am »
OK, thank you for your support.
Logged
OakCorp Japan
Yuji Yamauchi
Print
Pages: [
1
« previous
next »
RailClone
RailClone Pro (*)
About UV
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
